Battery flat and now lost one touch windows?
RyanB88
Hi
As title - had an issue with my battery (car stood for 2 months) and obviously the battery went flat
Back up and running now with a new water pump (thanks chris1981) but I’ve noticed my one touch windows don’t work anymore. Any ideas? I’m sure I used to have them before the battery went flat..?
PS I already tried the reset procedure which didn’t work -
1. Turn ignition on
2. Press and hold window down, when window reaches the bottom hold for further 5 seconds
3. Press and hold window up, when window reaches the top hold for further 5 seconds
4. Release and turn off ignition
There's seems to be a number of different reset procedures for BMWS on the net. For example i use a variation of what you do. I hold down for 10 secs then release the button and after a couple of secs repress down. Vice versa for the up position and I do the whole thing twice. Seems to work for me
Ryan if it doesn't work and you are anywhere near cambridgeshire then i have Carly so could try that. :thumbsup:
1. Turn ignition on
Are you attempting this with the doors shut?
