Battery draining
Any help appreciated my battery is draining after 2 hours, I took it to a local garage they put a new battery in and the same thing happened. I have Carly and ran a diagnostic iPhone Fault Report - Carly for BMW - 33.2.7 - 2018.01.11.1856 FV
ID1: 2701F62C-4635-40C3-A697-C8C63B094912-609-0000003C69A34969-b21
ID2: 52D8E687-9FBD-460A-832C-93DF05A79ADD-609-0000003C69A34AF8-112e
INFO: >0505CABAAA9C8D7565583B2E2810<
2018-01-17 13:52:54
BASE: E85
BUILD-YEAR: 2007
MODEL: Z4 (E85, E86) Automatic engine recognition (91)
ADDITIONAL OBD: OFF
FAULTS: 7
ECUs: 13
BATTERY: 14.6V
DEPTH: Normal communication
SPEED: normal
CONNECT: Fast Connection
VERSION: 11.2.2
DEVICE: >Jon's iPhone< >iOS<
WIFI: >Carly Adapter v00<
ELM: ><
COM+: >UNKNOWN<
0. Motor Control:
Engine / Motor:
- Fault: DME digital motor electronics main relay, input signal
- Code: 002ACB
1. ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC:
ECU OK, no fault code
2. Airbag:
Satellite B-pillar left / B-Saeule links:
- ECU not present/no answer
Satellite B-pillar right / B-Saeule rechts:
Airbag:
Airbag:
Airbag:
Airbag B-pillar left/ B-Saeule links:
Airbag B-pillar right/ B-Saeule rechts:
3. Transmission Control:
Transmission / Getriebe GS 19:
Transmission / Getriebe GS20:
4. Instrumentation:
Instrument cluster / Kombiinstrument:
Center-Console/ Schaltzentrum Mitte:
5. Light/Rain Control:
Light / Licht:
Light / Licht:
6. Heating / AC:
Aircondition / Klimaanlage:
Additional heater / Zusatzheizung:
7. Park distance control / PDC:
Park Distance Control / PDC:
8. Sunroof / Roof:
Sunroof / Schiebedach:
9. Audio / Navigation / Communication:
HiFi:
Radio:
HiFi:
Navigation:
Video:
10. Seats:
Seats / Sitze:
Seats / Sitze:
11. Systems:
Gateway /ZKE:
- Fault: Central short-circuit or open circuit on the engine hatch
- Code: 00003D
- Fault: Interior Lighting: Open circuit
- Code: 000048
- Fault: Power windows: cable break or jam protection strips de-standardisation/Error EKS Electronic driver s door
- Code: 00000D
- Fault: Power windows: cable break or jam protection strips de-standardisation/Error EKS Electronic passenger door
- Code: 00000E
Central info display / Zentrales Infodisplay:
Tire pressure control / Reifendruck:
12. Body:
Elektronische Fahrzeug-Immobilisierung:
- Fault: general reset
- Code: 0000FF
- Fault: Power On Reset at diagnosis warm reset
- Code: 00000F
Steering wheel / Lenkrad:
13. Motor Control:
edinburghjon said:
Any help appreciated my battery is draining after 2 hours, I took it to a local garage they put a new battery in and the same thing happened. I have changed the interior lights to LED 6 months ago with no issues. I have Carly and ran a diagnostic iPhone Fault Report - Carly for BMW - 33.2.7 - 2018.01.11.1856 FV
2018-01-17 13:52:54
BASE: E85
BUILD-YEAR: 2007
ADDITIONAL OBD: OFF
FAULTS: 7
ECUs: 13
BATTERY: 14.6V
SPEED: normal
VERSION: 11.2.2
ELM: ><
COM+: >UNKNOWN<
0. Motor Control:
Engine / Motor:
- Code: 002ACB
2. Airbag:
Airbag:
Airbag:
Airbag:
4. Instrumentation:
Light / Licht:
Light / Licht:
6. Heating / AC:
8. Sunroof / Roof:
HiFi:
Radio:
HiFi:
Navigation:
Video:
10. Seats:
Seats / Sitze:
Seats / Sitze:
11. Systems:
Gateway /ZKE:
- Code: 00003D
- Code: 000048
- Code: 00000D
- Code: 00000E
12. Body:
- Code: 0000FF
- Code: 00000F
13. Motor Control:
I have the same issue but mine doesn’t drain as quick. I’m guessing that the quicker it drains, in theory, the easier it is to diagnose.
I haven’t got round to doing this myself but will initially be trying the following:
“O.k.,what needs done is to leave the key out of the vehicle with the windows rolled up and make sure everything is off with access to the battery.
Set the meter to amperage or milliamp and disconnect the negative cable from the battery.Put the leads in the multi meter the correct way (negative in negative and positive in the amperage or milliamp slot if equipped).
Connect one cable from the meter to the ground cable that was connected to the battery and the other lead to the ground terminal on the battery,this way the current is flowing through the multi meter.
After around 5 to 10 minutes see what the meter reads for a amperage draw.Normally you want to see less then 50 milliamp or less then .05 amp.
If you see over this amount of a battery draw/drain then your vehicle has an electrical component draining the battery.
From here you would remove one fuse at a time with the meter still in place and observe the reading on the meter until you come across one fuse that allows the draw to read below the 50 milliamp.This is the fuse or circuit that has the component on it that is drawing down the battery.Make sure when you remove one fuse if it is not the issue reinstall it and move to the next waiting a minute between each fuse removed to get an accurate reading.
Once you find the fuse or circuit its on then you would look on a wiring diagram to see what that fuse powers and unplug each of those components one at a time until you locate the component causing the draw then this component would need replaced”
All those fault codes just look like the aftermath of a low battery voltage, so individual ECUs could not be contacted by the main diagnostic bus.
Have you got any aftermarket electrical equipment fitted, like Bluetooth kit or aftermarket head unit?
Chris
edinburghjon said:
No I don’t have any aftermarket electrics fitted apart from LED bulbs on the interior and on the number plate
..well that explains the interior lighting open circuit error. Dans6490 post contains good tips to finding the culprit but if a new battery is really going flat in 2hrs, that would mean a current drain of 20A or more! That sort of drain will cause heat if through any of the fuses in the fusebox so just have a feel to see if anything is hot.
The DME electronics main relay sounds a bit suspicious but you really need to read this thread where a member had a similar issue with high drain caused by the water pump running continuously. The thread contains some great info with which fuses to check etc... https://z4-forum.com/forum/viewtopic.php?f=3&t=101363&hilit=clamp
Thanks for all your replies, I’m in very poor health so I’m loooking for an Indy in Edinburgh, or considering going to the local dealer. My usual Indy is offf sick just now too
Thanks, water pump constantly running was the problem, took my local specialist a while to locate, new water pump and logic board required.
Result! I'm not quite sure what the logic board is that you mentioned though. All the electronics for the pump are built into it.
