markplant said:It could go in to transport mode,
I could well be wrong an got it wrong way round , I just recall from posts that you don't want itsrhutch said:markplant said:It could go in to transport mode,
I thought disconnecting the battery didn't cause this. Thought it was due to the battery draining over a period so the car shut things off.
Saying that I would leave connected though on a battery maintainer, as I in fact do.
Good point that I did need to redoAdam D said:I would leave it connected and keep the charge topped up, your windows will not lower or raise when using the doors if you don't.
D4dawg said:Good point that I did need to redoAdam D said:I would leave it connected and keep the charge topped up, your windows will not lower or raise when using the doors if you don't.
Adam D said:D4dawg said:Good point that I did need to redoAdam D said:I would leave it connected and keep the charge topped up, your windows will not lower or raise when using the doors if you don't.
More to avoid damage to the glass/seal than losing the one touch function![]()
