Afternoon all, my 30i has a BMW battery on board, but I don’t know how long it’s been in the car. Among all the numbers on it is the date hidden somewhere?
I thiunk this only works if any new battery was registered. You could end up throwing away a good battery if it has been replaced and not registered. Pop in to any garage and get a discharge test done, takes a few minutes and will tell you for sure...tintoverano said:hi,
you can read out using software, when it got registered with the car, though it is not production date, if that's what you want
mr.tourette said:Like so.. Negative terminal on my old battery.. Week 22 of 2009
Yes it needs an agm for the brake regeneration system.. i bought the Lucas 096 agm from Tayna.. just under a 100 quidBig Bad Boris said:mr.tourette said:Like so.. Negative terminal on my old battery.. Week 22 of 2009
Ah yes, hadn’t seen that. By strange coincidence mine is 21\09 so a week different to yours.... and also 11 years old. Time for a new one methinks !
The car isn’t stop/start, does it need an AGM battery or is a “normal” one sufficient?
