Does anyone know the torque setting for the top nut on a Bilstein B12 kit damper?
I've had a look at the manual on their website and they give a number of possible settings depending on the nut size which I don't know:
13lb ft if M8
19lb ft if M10
34lb ft if M12
54lb ft if M14
83lb ft if M16
Am I right in thinking you need to get it started with a deep socket-spanner while holding an allen key through the centre, then you can fit the damper to the car and use a torque wrench to tighten to the correct torque as the vehicle weight will stop the shaft spinning?
Thanks for any advice
Jeremy
13lb ft if M8
19lb ft if M10
34lb ft if M12
54lb ft if M14
83lb ft if M16
Jeremy
