A Anonymous Guest Mar 1, 2010 #1 Been trying to upload an Avatar but when I cut/paste nothing shows in the square box, I know the size is 120x120 Where am I going wrong?
P PawnSacrifice Veteran South Oxfordshire Mar 1, 2010 #2 You need the file, you cannot copy and paste. If this is stored on your hard drive then use the 'Upload from your machine:' function - browse to the file and then click submit. If you're using a file on PhotoBucket enter the image URL, without tags in 'Upload from a URL:' and click submit. I'd use the local file option as it's easier.
M mcbeee Veteran Chestermere, Alberta Mar 1, 2010 #3 If it's on Photobucket, you use the "Direct Link", second from the top in the block of links for the pic. I just changed my avatar to make sure. Good Luck, by the time this is done you'll have "Microsoft Certification"...
A Anonymous Guest Mar 1, 2010 #4 mcbeee said: Good Luck, by the time this is done you'll have "Microsoft Certification"... Click to expand... Well I don't want to boast but see my new Sig and Avatar
M mcbeee Veteran Chestermere, Alberta Mar 1, 2010 #5 I spotted the cat avatar right away on a different post, congrats, .... you are now Board Certified ...oops...I mean MS Certified.
