Autoglym Polar
Double Zero
Milton Keynes
Hi all,
I've been using polar foam with some good results, I've not used the car in the last 4 weeks, working from home, the car is filthy how can a car get so dirty without going anywhere, I digress I need to give it a proper clean, should I apply wax/sealant after cleaning and claying or clean clay polar seal then put the wax/sealant on after.
Are you asking for a proper order? If so:
active foam - 1-2 min on car
rinse
prewash
rinse
wash
rinse
deironizer + tar removal
rinse
clay + lube
rinse
quick wash
rinse
dry that car with a towel
put into a garage and you can work on paint
