Putting the car in Manual mode only allows you to control the gear youre in, You still retain comfort setting if thats the drive mode you had been in prior to changing to manual.
The only thing that changes the throttle response, drive characteristics is the drive mode selector.
If youre looking into getting more of a throttle response of sport mode but keep comfort settings like the softer suspension the same i would look into a throttle tuner, I used one on my Alfa and it was great for that. It doesnt make it faster just changes the throttle aggressiveness
https://www.bimmerworld.com/Chips-Software/Plug-Ins-and-Tuners/Speed-Buster-Drive-by-Wire-Throttle-Tuner-App-E85-E86-E89-Z4.html
1. Comfort Mode
Throttle Response: Throttle input is more subdued, resulting in a smooth and gradual acceleration. This makes Comfort mode ideal for relaxed city driving and cruising.
Steering: Steering feedback is lighter and easier to maneuver, providing a more relaxed and comfortable driving experience.
Suspension: If you have adaptive suspension, it stays in a softer setting, absorbing road imperfections more effectively and creating a smoother ride.
Transmission: The transmission upshifts earlier to prioritize fuel economy over performance. In Comfort mode with automatic shifting, the car will stay at lower RPMs, giving a quieter and more fuel-efficient drive.
Best For: City driving, long-distance cruising, and when you prefer a calm, comfortable ride.
2. Sport Mode
Throttle Response: Throttle becomes sharper and more responsive, so even a small press on the accelerator results in quicker engine response. This makes the car feel more agile and engaged.
Steering: Steering weight increases, providing more direct feedback and a sportier feel. You’ll experience greater precision when cornering.
Suspension: With adaptive suspension, the shocks firm up slightly to reduce body roll, enhancing stability and grip when driving on twisty or winding roads.
Transmission: The transmission holds gears longer before shifting, keeping the engine in higher RPMs to ensure quicker access to power. In Manual mode, it won’t automatically upshift, giving you full control over gear changes.
Best For: Spirited driving on backroads or in situations where you want a livelier response without pushing the car to the extreme.
3. Sport+ Mode
Throttle Response: The throttle becomes even more responsive than in Sport mode, so any input on the accelerator is amplified for maximum responsiveness.
Steering: Steering feel remains as tight as in Sport mode, enhancing precision for performance-focused driving.
Suspension: Suspension stiffens further if you have adaptive dampers, providing maximum control during high-speed cornering by minimizing body movement.
Dynamic Traction Control (DTC): This is a key difference in Sport+—it partially reduces the traction control system’s intervention, allowing more controlled wheel slip and drift angles. It’s designed for drivers who want to push the limits, especially on dry surfaces.
Transmission: Holds gears at higher RPMs to keep you in the optimal power band, just like Sport mode, but with even more aggressive shift patterns.
Best For: Aggressive driving, high-speed cornering, or track conditions where you want maximum performance with minimal electronic intervention.
Summary Table
Mode Throttle Steering Suspension Transmission Traction Control
Comfort Smooth Light Soft (if adaptive) Early upshifts Full intervention
Sport Sharper Tighter Firmer Holds gears longer Full intervention
Sport+ Sharpest Tightest Firmest Aggressive shifts Reduced intervention
In essence:
Comfort Mode optimizes comfort and efficiency.
Sport Mode increases responsiveness for dynamic driving while retaining stability.
Sport+ Mode pushes performance boundaries, ideal for situations where you want a more intense, less-restricted driving experience.
