Audio System ID
nealjr
I thought I had the Top Hifi (Logic7) system but I'm not longer sure because I don't believe I have and amp installed near my battery. Pics to follow...
=https://picasaweb.google.com/lh/photo/9iUG9JAW2YEKX-3Iz_fCFw?feat=directlink
=https://picasaweb.google.com/lh/photo/aLfDsKWie_oQ-rPy2nzJLg?feat=directlink
Mind shedding some light? Any specs would be much appreciated.
2007 Coupe. Business CD HU w/ DSP. No cubbies behind the seats.
Referencing:
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=15177
http://www.billswebspace.com/E85Z4Communications.pdf
That looks very similar to mine which is a Professional Carver system. It's an early '03 car so might have changed with the face lift. Check to see whether you have DSP settings as I think this is the DSP Amp shown in your pics. If you don't have the cubbies I assume you have the speakers located here which is similar to mine
I have DSP and the black box mounted to the rear side of the divider is the control box... actually says DSP on it. I do have a box located to the left of that which I haven't identified yet but it doesn't look much like an amp to me. I more inclined towards it being part of the internal phone system.
Pretty sure thats the bluetooth ULF module although not had a rummage so I might be wrong.
I don't think it is actually - I'm pretty sure the Bluetooth is a silver box over on the left (mounted at a slight angle for some odd reason).
I think only the early models (or just pre facelift ones) had an amp installed near the battery
i have a 06 roadster with logic7 system and the amp sits on the firewall between passenger compartment and the boot - just as on the picture you linked nealjr,
