After finding out that my dealer couldn't upgrade the standard audio in the Z4M without a lot of cutting of wiring, I decided to take the less evasive route and install and aftermarket amp, a set of 3way speakers and a signal convertor.
The inputs from the head unit were taken to the rear of the car to an LC6i which transforms the outputs to the ideal inputs for an aftermarket amp - a Rainbow Ipaul 2 channel one with excellent sound quality. LAst of all a set of Rainbow SLC 365 Kick 3 way speakers were added.
The rear speakers were kept now as an fill in type speaker and two rear subs may be added at a later date, but for now the difference is dramatic. Much more punch than before and a nice range from the new Rainbow bits of kit.
The following kit was used:
Rainbow Ipaul Amp
Rainbow SLC 365 Kick speakers
LC6i
Amp kit & connectors.
A local installer put it all in and I just need to get the slight interference from the right hand speakers out (think its the telephone module being next to the amp...) and were done!
The amp was mounted in the BMW bracket which was altered slightly and their good velcro mount system was extended with a few lengths of new velcro.
With the rear trims back on you'd never know it had been touched - very important for me.
So a pretty poor pic here - still doing some minor fettling to make it look better but not bad for £800 all in! I would have went for the bigger amp but it wouldn't fit behind the seat area without shifting some modules and at 415mmit was too long. The smaller 2 channel amp, £50 cheaper at £250 does the trick and fits beautifully in the space!
Couple of pics...
Stock image
Rainbow Ipaul Amp
LC6i
Couple of pics...
Stock image
