Auc Sensor Location
wanderer
Has anyone replaced their AUC Sensor?
Any pointers as to the location?
On my E90 it's easily located but I don't have a clue on the E89.
As you look at the engine bay its on the right hand side under the scuttle deck under the right hand wiper looking from the front of car..
Thanks guys. I've ordered the sensor but still having difficulty figuring out how to access it.
At (1) below I can see an electrical connector through the vent.
However the manufacturer image as shared above by Big Bad Boris and on realoem shows the location on the left side from the front or right hand side when driving. FYI, my car is a right hand drive
Either way, whether it is located on the left or right, how would I access it?
Do I remove the plastic panel at (2) below?
That would involve removing the wiper arms.
Then, does it unclip or is it bolted down.
Thanks for the assistance!
It’s near 1 marked on your diagram..we’ll at least on a 2012 MY20i UK spec..it’s quite common for TIS to show the majority US/European picture/diagram..
You need to take the windscreen wiper off to get the scuttle deck loose enough to get access to it, if memory serves me :thumbsup:
:thumbsup:
Thanks for this info.
I thought I'd ask first because I have a tendency to eff things up the first time around!
I will record a video when i do the job.
:thumbsup:
Thanks for this info. :thumbsup:
Put it this way..I stripped down the car based on what TIS said..zippo sensor..
I stripped the other side down, voila an AUC sensor :thumbsup:
Hi.
Do you find out AUC sensor location pal?
I have the same thing to do it :!:
Where did you get your new sensor, plz?
Thans for any info in this case.
Hi.
krystiangesicki said:
Hi.
64119240180 Sensor f. AUC
Google it and find your best value supplier.. https://www.lllparts.co.uk/search/64119240180-Sensor-f.-AUC
Whilst you have that panel off get some mesh to put over the cabin air intake.
I did as when you pull out the pollen filter load of seeds and twigs fell out.
Another bit of rubbish design.
Hi.
I purchased the sensor from lllparts.co.uk.
I have not installed it yet.
Probably do it in the spring time.
Hi! i have the same thing to do, so, please let me know if you remember where this sensor is located on my z4 E85 (2003)
Thanks so much!!
Thanks so much!!
Pass I only know E89s location..
