synthedup said:
Hi guys, as per the title, has anyone any experience with the above type?
I've just put a set on recently to try. Having used 3 sets of nankang ns-2rs over the last year or so I can only really compare to those, as my memory of the PSS I had before those is long gone. Anyway I guess it's relevant as I suspect you're in the market for a track orientated tyre and the NS2-Rs get favourable reviews for their price.
Immediate findings were that the tyre is pretty square and slightly wider than the ns2-r. Ride comfort is improved over the NS2-R, the tyre doesn't feel as stiff in the sidewall (at least in vertical compression).
I had the opportunity to take the car to combe the other day which I have done many times over the years, so a fair comparison in lap time.
With the exact same setup the tyre gave me a whole second improvement, which to be honest shocked me quite a bit. I was expecting half a second at most. Initial turn in is far better with the AD08 and they hang on better allowing you to really attack some of the more technical corners. The day was also wet early morning, where I found they gave great grip and let go quite predictably. This behaviour of course requires heat in them though. On the journey there on the road through some small standing water they were not particularly confidence inspiring but then that is to be expected for any of these kinds of tyres.
Wear rate seems to be far improved over the NS2-R also which I'm really pleased about as given the increase in performance I think it is easy to justify the additional cost over the NS2-R.
Suffice to say I will definitely be considering another set next time around, though the urge to see what difference a set of Cup 2's would make is strong, though I suspect diminishing returns.
Hope that helps.
Small vid of the combe day, pleased with my best time of a 1:17.3 which just pips a cayman gts recently tested by autocar there and just 0.5 second behind the M4 they also tested (though my optimal lap time was a 1:16.8 also.... next time :evil: )
[youtube]BsxHyGHcLC4[/youtube]
