Anyone used Megs scratch x on alloys?
andysat
Hi all,as above really,noticed afew small scratches on my alloys today as i was washing etc,i have some scratch x not the 2.0 version and wondered if it would do any good or make matters worse?-thanks
Depends how deep the scratch is. Scratch-X is an aggressive polish, designed to take very fine layers of clear coat off thus removing the scratch. Your alloys will also have the same sort of an idea with a clear lacquer on them to help protect the underlying metal work from all sorts. Scratch-X I would say shouldn't do any harm but the clear lacquer on alloys is a lot tougher than your car body so I'm not sure you'll see much difference without a lot of effort..
Is scratch x that agresssive?-i remember seeing a 'scale' of products lined up and scratch x was iirc the least agressive?
Adamski said:
It;s a filler, should be ok :thumbsup:
No it's not a filler. It's a polish.
Meguiars Scratch X 207ml Product Description
The Meguiars Scratch X is an exclusive micro-abrasive system, which removes paint blemishes fast, while restoring a brilliant high gloss shine. It is ideal for the quick removal of isolated paint scratches or blemishes, whenever they occur on your car, enhancing the colour & clarity of the paint.
Features & Benefits of Meguiars Scratch X
Fine scratch & swirl remover
Enhances paint colour & clarity
Quick & easy to apply
It'll be fine on your alloys just may not produce the same effects as on paintwork unless you put a bit more elbow grease into it.
Was thinking of Megs #9 Swirl Remover. - its the one with fillers...
