Anyone running 235/35 Up Front with lowering springs?
sunnydays
Is anyone running 235/35/19 with Eibach Lowering springs?
I have the following:
235 / 35 / 19 Michelin Pilot Sport 4S - Fronts
8.5J X 19 ET35 Alloys - Fronts
12MM Hub Centric Spacers - Fronts (Alloys are 6mm further in, But also 6mm wider a side, the 12mm spacer will line these up with the rears, concern here is that these will catch the front fender under cornering load)
265 / 35/ 19 Michelin Pilot Sport 4S - Rears
10J X19 ET40 Allys - Rears (12MM Wider a side, fit fine with no modifications required, will rubbing be a potential issue here under cornering load?)
As above, my concern is that the fronts will catch the fender under load, does anyone here run a similar setup?
Mr Wilks has a wealth of knowledge on these things I am sure he will be able to Point you in the right direction.
8.5j et 35 front with a 235 35 i really don't think would be a problem with or without the 12mm spacer even lowered :?
You can at least try initially without spacer knowing the wheel face will sit as a 296 or 326 would & then try the 12mm if you really want the wider stance ?
Thanks Mr Wilks, will try both and report back!
