Anyone knows if those can be fit on e92
z200
ATHENS
Hi to everyone maybe anyone knows if those wheels can be installed on e92 i run them on my z4 2005 roadster thanks allot style 135
I'm sure you can compare specs between those and the E92 wheels, but from my guess, I'd say no. I've been looking for wheels for the wife's E91 and not once have I seen E46 style rims on the newer model.
Yes they wil fit.
The tyres should be slighty different sizes though. The rears should be 18/40/255 and the fronts 18/45/225, that said they will be fine as they are as the difference is marginal.
Huh, I think you're right DannyBoy. Just looked at the specs on tire rack and they look identical. This opens up a whole new avenue of wheels for me! :thumbsup: Learn something every day. :D
E46 specs.
Front Fitment
18x8
Offset: 40mm
Backspacing: 6.10"
Bolt Pattern: 5-120
Rec. Tire Size:225/40-18
Optional Rear Fitment
18x9
Offset: 45mm
Backspacing: 6.80"
Bolt Pattern: 5-120
Rec. Tire Size:255/35-18
E92 sepcs.
Offset: 40mm
Backspacing: 6.10"
Bolt Pattern: 5-120
18x9
Offset: 45mm
Backspacing: 6.80"
Bolt Pattern: 5-120
