Anyone got a One Touch Manual to Hand?
t20lau
South Yorkshire
if anyone has one can you please tell me the colour of the cables and where they go?
Left my manual at work and my One Touch doesnt seem to be operating properly...
The roof went down without a problem but wont come back up!
Just trying to dig that out now, but again I had this problem, only way I oculd close the roof was with the key in the door
your in luck just remembered I posted it before
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=2594&p=38330&hilit=+reinhold+remote#p38330
Did you manage to overcome this issue? Can you please explain how you managed to close the roof with the key in the roof? Do I just hold it in the lock position or something?!
Yes, as before it was connections, cant remember what I had been messing around with but know I had a little panic when I oculdnt get the roof up.
what have you used to connect the module Scotch locks?
something like scotch locks, its the block things which have screws, dont know what you call them...I'll give it a quick go now and if it doesnt work i'll just wait till the weekend...at least now my windows are working again!!!
OK, so you can remove the module easily to see if thats at fault, other than that I owuld again put it down to dud connections, if you can close the roof with the key in the lock this again would suggest this.
Right heres the deal, I've removed the module...and everything is working fine, windows auto up, down, roof opening and closing...
As the moment the wires are still ready for plugging straight back into the module, all i've done is unplugged it and wrapped insulation tape round the connectors to the module sockets...
Anyways, just been outside and plugged everything back into the module...windows are working, and the roof came down without an issue...
Then when it came to putting the roof back up nothing happened, the button didnt light up, nothing came from the motors...nothing...
So i removed the module, taped everything back up, and everythings back to stock and working! Any ideas? is the module just broken?!
Cant for the life of me get this thing to operate properly...
Everything is working now, but the roof doesnt come back up! Once I plug the One Touch in, the button seems to lose functionality!
Heres an idea of how the module is connected...
Each wire from the car or plugs are connected to something like scotch lock, its the block things which have screws, dont know what you call them...This is in turn connected to a piece of wire on the other side which has the connectors to the module connected to it! Once I unplug the module i simply tape the applicable cables together to retest and everything is fine, however, when I plug the module back the roof wont come back up!
Is this just a broken module?!
Is there anyway of testing it?!
