Any help with back luggage net mounting?
Diego_F
Hello. I just got the net that goes begind the seats (large one side to side), but I can't mount it. I find it short and a very strange way of mounting to the sides. Maybe there is any part that is missing or not mounted before. Also I find very hard to adapt to the bottom tabs.
Anyone can share any pictures so I can see how it's mounted?
Kind regards
Just looked at mine. Try removing the little triangular cover at the top of the mounting point so you can get the hook of the net into its slot. When you say it’s short, have you pulled it enough to stretch it fully? It will need to be under some tension or the top will just flop down and not hold anything back. As for the bottom, the metal rod that goes through the seam on the net simply snaps into the fixings - might need a hard press!
Done! The clue was removing the top covers just pulling. Then you can properly attach the guide, put the little cover again and then stress from the other side so it fits. Finally you have to hard push the bottom part to fit it.
Thank you again @EssexZed
When I got my car, those little clips were in the glove box and I had no idea what they were for. Looked up the part number on real oem and bingo!
The bottom of the net wasn't in the clips either....quite hard to clip in, but did it in the end.
