Any Dension experts out there?
Nick C
 UK
Please help!
The car is a Z4 3.0 built mid 2003. It has prof. nav, Carver(DSP) and Bluetooth, all factory fitted.
The Dension interface is an Ice-Link Plus, which was formerly used in a MINI. I'm using an iPod Mini.
This combination used to work a treat in my old Z4 which was the same spec', but didn't have Bluetooth.
I've wired everything up and the sound is great, but when I switch the source to the iPod, the satnav screen leaves the map display and the screen says speed dial at the top, with the track ID displayed underneath! If I then switch back to the map, it remains for a few seconds and then returns to the speed dial screen.
How do I configure the Dension Ice-Link Plus to allow me to have the satnav display at the same time as listning to the iPod?
Thanks.
It might possibly be the text function has not loaded properly, apart from that it might mean a software re boot for the sat nav etc,
I have the dension, dat nave, blue tooth combo and it works fine,
You might find this link helpful to re load the text display,
http://support.dension.com/support-center/index.php?x=&mod_id=2&id=105
Rusty
Problem solved.
I downloaded the instruction manual and there is a menu that is specific to bmw's which allows one to sort out the ID3 info.
Thanks for your help RustyZ4. :thumbsup:
