S Syrinx Member Nov 27, 2021 #1 Hi All I plan to change the antifreeze on my e85 2 litre n46. Can someone advise where the engine block drain plug is please, whether it has a crush washer and the post change bleeding technique? Thanks in advance.
Z Zedebee Lifer North Hampshire Dec 3, 2021 #3 Brouse said: Any luck on this? Click to expand... You should ask the question separately, Brouse, Syrinx has the 4 cylinder engine.
B Brouse Member Dec 3, 2021 #4 I know, was enquiring to see if Syrinx made any progress as I noticed there wasn't any replies
S Scooba_Steve Lifer NW London & Somerset Dec 3, 2021 #5 Loosen coolant drain connector (1) on engine block. Drain, catch and dispose of coolant. Installation note: Replace sealing ring. Tightening torque 11 11 5AZ.
S Scooba_Steve Lifer NW London & Somerset Dec 3, 2021 #6 Syrinx said: post change bleeding technique Click to expand... Says to use vacuum filling unit.
