Hi all,
Sorry to start another thread, i've searched but can't seem to find the answers I need.
My roof worked perfectly yesterday morning, opened and closed as normal.
Yesterday evening I went to go out and put the roof down, and it has stopped. The windows will go down, and the roof motor near the windscreen will unlatch itself from the windscreen, but after this there is absolutely no movement at all. The motor is making a noise like it's straining to do something but there is no movement whatsoever. I can pull it back about 5cm but after that it's stuck solid. If I try and close it from this barely open position, it will close and latch fine.
The lights on the buttons are red not yellow, and will flash when the roof stops moving.
I've read a lot about the bowden cable in the boot, and had a play with this, tugging it in and out etc, but no luck. Some people are stating there is a brass part that might be seized but I have no clue how to access this or what I'm looking for, and no threads i've found have included pictures.
Considering the motor is making a noise and unlatching itself fine, I can't get it down manually and it just stopped working in a 6 hour period, I'm inclined to think it may be jammed rather than the motor packed up?
Any help is appreciated, and sorry for starting another roof thread!
