Another Roof Motor Sorted !
Number5
Elite
 Bristol M4/M5
Site Supporter
I had the pleasure of meeting Kevin (aka BKDiver) today to look at his failed roof motor.
He's a lovely bloke and has a very nice, low mileage 2.0 Roadster which is his P&J. The roof motor packed up only a couple of weeks ago, so I was optimistic we could revive it. He dropped the car off with me this morning at 9am and then ran the 16 miles home !!! ( I couldn't beleive he didn't run back to collect it later!)
At first it was difficult to work on as despite pulling the bowden cable the hydraulics would not release and allow me to drop the roof manually to access the area where the motor is, but eventually I got it moving and managed to get in there.
This was the result when it eventually came out.. Not good and although the well was dry, the roof motor casing was absolutely full of water and sodden sponges.
I managed to get the motor cleaned up and running, but it would not start itself unless I turned the spindle manually, then it ran no problem at all. Even after running it for 20-30 minutes on a battery, it still wouldn't start on its own so we popped in a refurbished one I had on the shelf and relocated everything neatly to the boot behind a false panel.
I topped up the hydraulic fluid level and this then stopped a slight pause occuring mid cycle. After a few more cycles everything speeded up and worked far more smoothly, resulting in the desired 8-9 second operation.
A rewarding few hours work and another happy customer. Thats 11 I've done this year including a few forum members: JamesUK, Ady, Chris2.5, Wackracer8, BKDiver and a friend of Spikeys, not to mention 2 of my own cars, so if I can help to keep all of the West Country Zeds enjoying their top down motoring its worth it !
I'm located in Bristol, so if you're in a similar situation and need your roof motor fixed or relocated, just drop me a PM
Cracking work number5 :thumbsup:
Your too far for me to visit (and certainly too far to run home :oops: ) but keep up the good work :thumbsup:
Hi, how much do you charge for this work. I assume there is no other issues with re-locating the offender ??
regards Stan
srhutch said:
Didn't relaise you had done 11 Alan :o
Good Work :thumbsup:
11 I can recall, but maybe another one or two I cant !
regards Stan
No issues at all, just all positives. BMW should have done this in the first place and certainly at the change to facelift model.
Somewhere between £120 and £150 depending on how long it takes and the customer wants the roof right out or not. I've managed to do some with just partial removal lately, which is cutting down on the hours spent.
I'm getting quicker, but every one seems to present a different issue. Some come out easily and then the motor is difficult to revive, some are difficult to get out but the motor plays ball immediately. I've had some roofs that come out but just refuse to go back in. Yesterdays roof refused to drop, so I couldnt get anywhere near the hinge mechanism to begin with. Yesterdays took about 5 hours all in with my lad helping me on the two man bits but we spent an hour or two messing with motors. I'd be happy if I could guarantee 4 hours, including the making and fitting of the false panel. I've only managed it once and that was on my own car !
I'm still waiting for the one that comes straight out, with a shiny motor and goes straight back in ! However, I've not relocated a working one yet. all of mine have been failed or failing motors that have needed a bit of work on to revive them.
firebobby said:
Sooooo, who has moved the most roof motors then?
Must be Durham Dave... he does 11 a week Followed by Boswer I would think.
Mine had a new motor in March, lasted 3 months, been arguing with the dealer twat who fitted it.
I give him 1 more try tomorrow then I come to Bristol
I've got mine down to around 1.5-2 hours which is partially removing some roof parts. The carpeted panels take an hour each to make but I do these in advance. I will not risk using a lever bar through the boot to remove the motor housing because of the risk catching one of the fluid lines.
I have had a few which look brand new and ready to relocate. Others i've managed to revive and clean up and some that won't i've fitted new motors from BMW. You'd be surprised the difference in speed with a brand new motor and a revived one.
I have lost count the amount i've relocated. Bristol is a good 2 hours from Hampshire so it looks like we have covered all bases Number5 to help people who want them relocated :)
