simonlpearce
Since i know how much you all like telling people to use the search function i figured i would stick this up for shits and giggles.
Car beeps constantly in reverse, done the usual trick of listening with the ignition on and car in reverse gear. All seem to click as regular as the rest, so that didn't work.
Now is anyone local to the Midlands/Worcs/Birmingham area that could help out a fellow member and diagnose which sensor is at fault with some computer wizardry.
Last question/observation - The sensor only started playing up since the wife reversed into the car. Is that just bad luck or are there any wires that run down the passenger side of the car that may have got damaged with her recklessness? I should also mention i cleaned the car after it was hit to fully see the extent of the damage so it possible water has also had something to do with it, just need to rule out the former.
Thanking you very muchly
