Seem to be going through a batch of noise issues. Probably as I become aware of each as I fix the last and things happen in batches anyway, especially where there’s a lot of development on the car.
Cured the exhaust touching its own mounting bracket when really hot that caused a squeak and now having fixed the whistling intake and removed that noise, it leads me to the next one that appeared on the Saturday evening of the Lakes event.
Those hanging over the bonnet were aware of a top end rattly clattery plasticky noise. This has now worsened quickly to a point of being annoying and very audible, but not worsening further despite 500 miles last week..
Done the usual stethescope piece to track it but can't identify anything obvious. Found the idler pulley (deflection pulley) a bit loose so replaced that as an obvious, but not that
I'm certain it's peripheral and not engine. Tempted to think water pump?
Symptoms:
Appears once the engine is slightly loaded i.e. in gear held on brakes or gently pulling away, forward or reverse.
Never does it on idle or free revving of engine
Stops once the speed rises or load increased/decreased, so basically sounds like a bag of nails while gently driving out of the garage and housing estate.
Not temperature related.
First thoughts are idler pulley(or belt tensioner), alternator V belt, water pump?
Anyone had any of these go as they seem robust engine and my X5 has clocked near 100k on the same engine with nothing like this?
Symptoms:
What about feedback from car from run-flats versus non-run-flats?
