Beedub said:
Easty-5 said:
Did you got for soft or medium compound?
For the money you pay, it's hard to fault them. Just don't expect too much from them and you won't be disappointed
I went for the medium compound and I found they tend to go 'off' after about 10-15minutes at Knockhill, I can only assume the soft compound would go off even quicker. Knockhill is pretty tough going on tyres though so it's certainly a good test for them and one in which they done pretty well. I'd be interested to hear your thoughts once you've given them a go.
youve got that backwards, our compound the road ones will go off quicker, the soft, sticky tyre is the one aimed at trackways predominantly... ours is supposed to be a dual use semi slick with a decent amount of road use thrown in. i went in a tvr with the softs on and it was nuts, but the car was only 1000KG....
Hmm...not convinced I do have that backwards. Soft compound will offer more grip at optimal temperatures but will wear and overheat quicker than a medium compound. A medium compound won't offer as much grip but should be a bit harder wearing and last longer on the limit.
On a sprint circuit I would expect the soft NS2Rs to be decent. On a trackday where you are doing 15-20mins, not so. Nangkang NS2Rs were the sponsored tyre for the scottish BMW Compact cup championship. Those cars weigh less than 1000kg and the races typically take 20-25mins. I have not heard one competitor say anything good about the tyres.
I ain't knocking them for the money you pay. There just is no getting away from them being a budget Trackday tyre.
