An aftermarket stereo fitting question........
  • Start date Start date
A
Anonymous
Guest
Right can't seem to find the answer, so here goes....
Pin 13 is labled power antenna (refering to shipkillers awsome web doodly http://68.230.199.103:8080/Radio.html)
Now this may be a stupid question, but thought i'd ask before i blow something up!
Does Pin 13 need a remote live attaching (ie power antenna/amp remote from aftermarket HU) as the wiring lead I have doesn't include this connection! I'm assuming that the 'power antenna' wire is for a signal booster?
Regards :thumbsup:
Hi there, think I may have confused you. Pin 13 is from the factory HU and is connected to the white wire on the Z4 wiring loom.
The aftermarket wiring lead does not have this connection, so is this wire for a signal booster?
Shipkillers web link refers to pin 13 (factory HU) as 'power antenna' but as far as i'm aware you don't get an electric areial on a Z4, so is this a connection for a signal booster? and if so does it need a remote live attaching.
Regards,
Sorry to bump a 3 year old thread
My aftermarket HU has a "remote on" and "antenna" wire
Which pin should they go on the factory harness? Pin 9 and pin 13 ?
Many thanks!
