I have just posted a load of details on the audio side of the forum.
OK so you want a switched 12 volt hassle free scource.
The best and safest place is the fuse box back of the glove box, second row of fuses very left hand side, top contact
fit a flat blade and a flying fuse say 5 amps that should be more than adequate to kick over you amp.
Have you sucessfully tapped in to the BMW audi system, without it tripping the whole system out?
My Slick A7 Proc Comp amp put the BM system in to mute.
I ended up running a 5 seocnd timer and relay system to get around the BMW systems checks.
Works a treat.
If your worried about how to get a cable from the front to the rear - heres how...
Fuse box, drop cable out of the back and down the left hand side of the center consol (if you crafty no need to undo any screws or trims, cafeully push the cable behind the trim - the carpet will easily hold it in place.
Follow to the back (you have to move the seats about a bit to get it to the joint in the plastic near the up right plastic moulding.
Remove the plastic holder in the back of the consol, work holer out from the rear to the front end then pop out.
this give you a hole for access use a tig rod or similar to get a way of pulling the cable from outside the consol to the inside, make sure you push the rod on the outside of the carpet trim in the hole.
Attach cable and pull through.
Remove the plastic trim from behind the hinge of the flip down lid this just pops out.
feed cable through in to this area.
OK theres a hole on the right hand side of this area where the cable for the phone clip cable again use a tig rod as a guide wire and carefully poke through this hole about 8"
OK in the boot open and fold carpets out the way, you may have to open a hole by making a small slit in the carpet to allow the roof removal botton to be pushed through.
once the carpet is up you can see the mass of wires and the back of the DVD player.
With your hand fumble about under the DVD player, this is where the tig rod should be found.
Pul through pulling your remote wire.
do with as you wish there after.
Total job takes half an hour to an hour.
The good thing is you now have a fully working wire that isn't going to bu**er up you BM loom, it took me half a day to try all the other option but to no avail, ans this includes the pin 13 /10 on the back of the stereo - it isnt worth it.
For reference this fuse holder is switch directly on / off with the ignition switch - no timers no system shut down just a striaght on / off,
Hope this helps
Cysty
