Amateur machine polish - pic heavy post!
stevo///m3
 Leeds - you know where it is
I am no pro detailer - not by a long chalk. I'm not far past realising that a sponge is bad!! Over the last few months I've bought a few products here and there - more specifically, two job lots of stuff from CleanYourCar.co.uk. Spent about £100 first time round on Black Hole, sealant, some wax and a couple of wheel brushes. Next job lot was starting to get more serious - the DAS 6 Pro dual action (DA) polisher, a stack of pads and a few more products to go with it - including a clay bar. This does not inclde the odd trip to Halfrauds to buy a couple of mitts, a microfibre (MF) mitt and a couple of other oddities - I should say that I have bought quite a few MF towels from wherever I see 'em - pound shops (not great quality but OK for using on stuff other than the bonnet and bodywork basically). So I guess what I've really wanted to do is to really get stuck in to a proper clean cycle and also to see whether I can emulate some of the stuff I've seen online and be any good at detailing - bitten by the bug and all that. The car is awesome and probably deserves the treatment!. :driving:
My ladyfriend just will not let me spend the amount of time I'd like getting the car into shape - so I've been putting the "big job" further and further backwards in time. So last weekend I reserved the bank holiday Monday, told her to go do something nice and got on with it. I'd had a few the night before so didn't get started until about 10am and didn't get done until about 11pm. I missed out - to my mind - about three stages which I'd have liked to have done if I'd had more time and more facilities. Some of the phtoos below will put a bit of meat on the bones of this tale but, in summary, I don't have a useable garage, only a small-ish drive, a hedge pretty close to that and I've never machine polished anything in my life before! Anxious to say the least. It also took absolutely ages because I had to build the gazebo after I'd done the washing part - it all adds up - a one man build took me about an hour in itself.
Anyway, the cleaning involved:
- rinse
- wheel clean using the wheel arch brush, pokey-through-the-spokes long brush and mini lugnut brush
- 2 bucket wash using two mitts
- dry with large MF towel, pat down
- clay bar all over the vehicle exterior, water as lube (Bilt Hamber clay - only requires water) - I have no idea when my car was last clayed (I certainly haven't done it on this car or any other - ever) - this stage aone took 3 hours and the paint was beautifully smooth afterwards
- Wipe all over with spray wax as Imoved from panel to panel with the clay - just a cheapo Turtlewax spray, more used as an impurity remover/lubricator rather than as a wax
- DA polish with Meguiars Ultimate Compound, wiping down panel by panel - just one pass - probably would have liked to have done 2 passes as there are still some swirls left - I think a slightly harder pad would work next time and I probably should have applied more pressure as well. I also have some AG Super Resin Polish (SRP) from a few years back (probably the old stuff rather than the apparently new improved stuff) which I would ideally have liked to use after the Ultimate Compound
- Black hole applied with DA - just one pass and a pretty wuick one at that, would have preferred two but by this time it was getting late... I think it may have been wise to keep this one for 20 mins or so but time was ticking away
- sealant wiped all over the car by hand, left for 30 mins and then wiped off. I do have a pad for sealant application but, having wiped it on by hand, I'm not sure I'll use the pad next time either. Just one coat - again, two is preferred I believe.
Products used:
Wheel brushes, Chemical Guys blue wheel cleaner, MF mitt
AG car wash shampoo conditioner, two lambswool mitts
Bilt Hamber clay bar and water
TurtleWax spray wax + MF towels
DAS 6 Pro with green Hexlogic pads (5.5 inch and 4 inch)
Meguiar's Ultimate Compound
PoorBoys Black Hole - blue hexlogic pad
Poorboys EX-P sealant - MF applicator
That's it. As you can see from the above, ideally I might have done:
- another Ultimate compound coat
- a SRP coat
- possibly another Black hole coat
- another sealant coat
- at least one WAX CCOAT - which I just ran out of time for!! :(
Realistically, it's a two day job unless you are litterally all set to go from the first minute of the day with a large garage and all your kit set up and know exactly what you are doing. Oh, and if you're stuck like me and use a gazebo or similar, whilst it did do a very good job at keeping most airborne impurities (pollen and the like) away from the car, do try and get one that is waterproof!!
Anyway, a few shots to show how I got along.
I should've taken a load of shots beforehand but didn't - although I did get this one of the bonnet (power bulge is towards the top):
This shot shows (badly) some of the marring pre=treatment:
Once the wash was completed, I needed to get on with the clay so had to start to build the gazebo around the car!:
This is mid-clay:
And post-clay:
Then I taped up the car - again, a first for me!:
Looks like a few shots of the new i8 (in black ofc):
Next was the actual polish stage. I didn't do any 50/50 shots because i was getting worried about the time so skip-to-the-good-bit:
iPhone shot first:
Then with the proper camera after the Black Hole had been applied:
Finally, couple of shots of the sealant:
I used PoorBoys EX-P sealant - very easy to apply with a MF applicator pad, goes on very easily but is slightly dusty if you leave it as the bottle says you should. It certainly did a good job, however, as the next shots of the water beading a few days later show:
Here's a shot of the overlight in reflection once the work was done. It looks a bit strange, as if there are watermarks everywhere but it is really the metallic flakes (greens, purples, reds blues in the main) which are not in focus:
By that time, I had to stop. Had to be up early the next day for a golf game (which I lost - bad back I reckon) and knew I'd have to dismantle the bloody tent before I could go!
Anyway, end of post. Phew! :)
Stevo
Hey Stevo - it's getting late - I'll have a read through this tomorrow!
Pictures look good though!
Reckon you're right about the golf and a knacked back - it's all hard graft and won't help that swing!
:driving: :thumbsup:
Thats a great effort... Love the pics.
The advantage is next time it will be easier for a quick clean. However for the sake of another 30 mins i would have added atleasts one wax layer to preserve it.
Black look perfect when clean... It just pains me as it get dirty and goes grey so soon :headbang:
Sent from my iPhone 5s using Tapatalk
Great effort and car looks fantastic. I bought a pop up gazebo for exactly this use. Takes less than 5 mins to put up. Would recommend these.
