Alpine CDE-126BT - first impressions
JimmyPop
 Glasgow
I've been weighing up my options for bluetooth/iPod connectivity ever since I bought the car a year ago. I finally narrowed it down to two options - either the Parrot Mki9200 with the standard Business system already in place or an Alpine headunit. I eventually decided on the Alpine CDE-126BT which I bought from CarAudioDirect for £180 including the iPod cable.
It was fairly easy to fit. Only two problems though - firstly I was sent the wrong aerial adaptor so had to pop down to Halfords to buy the correct one today. Secondly, there's not a lot of space behind the headunit to fit the harness and extra wires! It eventually all fitted in and seems to be sitting in place ok. The fascia that came with it feels rather flimsy and has to be put in place AFTER the vents which is rather odd. It has quite a nice finish, although in this case I was sent the grey rather than black fascia. It will do in the meantime but will need to find a black one from somewhere.
Must say I'm really impressed with the unit. My first concern was that it would look out of place, but I'm more than happy with it and don't think it looks to bad in the Z4. It has the added advantage that the lights can be changed to a different colour including amber which helps it blend in. iPod connectivity is really intuitive, much like the iPod classic clickwheel. The only problem is it can take a while to scroll through all the options, but I think this is more down to the fact that I have an iPod filled with crap! Parrot bluetooth is excellent. Pairs easily with my iPhone 4 and allows easy access to the phonebook. Sound quality seems fairly good so far but not really tried to have a conversation with the roof down yet. The microphone and stand seem a bit bulky and I've yet to find the best place to position it. At the moment I have the mic clipped on to the instrument cluster but thinking of taping it down to the side of the steering wheel column.
All in all, this seems to be a really good unit. I had initially planned to get the iDA-X305s like RichardG has, but I really would miss having access to a CD-player in the car and felt installing a compatible CD changer would be overkill. Overal, this was fairly easy to install and is easy to use. Would definitely recommend!
Hi Taz. No, I don't have MFSW although this is a planned mod for later in the year. It should be quite easy to wire it up for MFSW.
Works really well with my iPhone. Pairs easily on entering the car and making or receiving a call is simple.
i am seriously considering the parrot mki9200, but if i found a radio that was fully compatible with all MFSW control (telephone) then i would prefer that option
my business radio does not show id tags urghhhh, thats my only complaint about the car
:thumbsup:
I've not owned anything but Alpine headunits apart from a Sony over 10 years ago - can't really go wrong with them. Mine lives in my van along with the amp and sub that were in my previous car, I've got not had any reason to drown out the 6-cyl in the Z4 yet :P
Grey facia? Want to swap your black vents for my grey vents? I'm looking to buy some black ones to match my interior...
He he ..... just saw this thread and thought the same .... Jimmy needs Grey vents a11y needs black ones .... job's a good un
Hey a11y, possibly. I was considering trying to find a black facia to match with the rest of the interior. If I don't have any luck, will let you know and we can do the swap on the Oban meet.
Looks good JimmyP, like you I was concerned about losing the CD player when I installed my iDA X-305 but it has to said with the iPod in the glovebox I have never missed it, did you amp up or change any speakers? Guessing not seeing as you don't mention it, in the pipeline?
Been toying into looking at Parrot options seeing as my ages old nokia handsfree cradle is redundant now I'm on myu 3rd N8 and it no longer seems to be working, might be a job for when I get back from the brain dead blinkered drivers here in Tunisia, they are not as bad Libya but they are trying very hard, never mind only another 3 1/2 weeks to go.
Just looked at the Parrot kit, do you have the screen and the rotary switch thing mounted somewhere or does it all work through the HU?
Hi Richard. It actually all works through the HU and works really well. At some point I'm going to get a MFSW and connect it up to that. I've not amped up or changed speakers but that's a plan for next month or te month after. Not too sure what Im doing with that so might need to get some tips from someone!
BTW, it was actually your thread on installing your Alpine unit which helped me figure out the fascia adaptor - I had no bloody idea what I was doing trying to install it!
It's a pity you're not back earlier - would have been good if you could have made it to the Oban run.
EDIT: Richard - can't you just install an optional Parrot bluetooth module to your headunit for the same functionality that I have? This one?
That link to Prestige Tyres is really useful JimmyP :poke:
I have been looking at the KCE-400BT but it gets mixed reviews that said it seems to be because people are setting it up properly.
I guess I just need to get my finger out when I'm home and go talk to someone and if possible get a demo.
I have e-mailed Alpine about it as all current info is for the iDA X-305s and mine is an iDA X-305 not sure what the difference is if any.
Glad my old thread helped out I tried fitting mine a few times before the penny dropped on the fascia.
Oops! Sorry about that - was copying that link for someone else. You're right though - it was the 400BT I was linking to.
The fascia was a bit of a pain in the arse really! Not looking forward to taking it apart again.
Upgrade wise, what else did you do - installed an amp and replaced 6 speakers? Anything else?
Not really, I installed the amp and put 6X9s in the storage bins behind the seats, replaced the footwell speakers (I intended to add door speakers but cocked up and ordered and ordered the wrong size, I might get round to it one day but I'm happy with the results I achieved) and left both the rear mids and tweeters as standard.
Nice write up Jimmy :thumbsup: Should look pretty natural when you get that black fascia sorted too.
