Alloys... What do you think?
LukeMace
 Northampton
Looking at a set of these at the min...
They are not staggered though.
Width: 8.5j
Offset: 30
Spacers on the rear would fix it though. Tempted!!
Machine monkey said:
Nice deep concave so you get a :thumbsup: hear.
You know where to come for spacers :thumbsup:
Very true!! :thumbsup:
Decent price at the min... (Think they are Audi wheels?)
Plus they would be easier to wash!!
Only problem now is I don't think I can fit my new 265s on these though :(
If they are Audi is the PCD not different ie 100mm on them 120mm on the zed? It can be fixed but you will end a spacer on each one. Bolt spacer to hub wheel to spacer. So they will need to be 15mm minimum.
Not sure what you mean by spacers on the rear would fix it as adding spacers effectively lowers the offset so would make the wheels stick out further. :-?
My Schnitzers are 8.5in ET43 with 7mm spacers on the rear and stick out an extra 14mm over normal 8.5in ET50.
8.5in ET30 would stick out an extra 20mm at the rear which would be ok but on the front they would stick out an extra 23mm which would probably put them outside the the line of the front wing.
you forgetting the fact,that oem wheels are nearly half a meter inside the arches :!: i run et24 9j at the front ,go calculate that
Calculate it yourself, I don't need to :)
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
think they will look ok
I have just found out that Axa insurance won't insure my car with alloys on it :headbang:
