Having replaced my shocks, springs, lollipops, rtabs and front drop links I took it for a hunter alignment yesterday.
This was on my '03 E85 3.0 SE on sports suspension. After much trawling on here I went for sachs, eibach pros, and meyle HD, so basically OEM except for 15mm lower than sports springs. Everything felt much tighter and the sloppiness in the steering was eliminated, most likely as the old lollipops were really bad.
Took in the geo settings for the M and once up on the ramp things got frustrating. Rear offside initial adjustment appeared fine. But the rear nearside was way out, even to stock settings. Couldn't get the camber lower than - 2.5 and the rear trailing arm appeared that the front couldn't move inboard enough so couldn't get much less than 0.20 toe out.
Alignment guy and I checked all the bushes on the upper and lower control arms and all seemed fine plus nothing seemed buckled or bent. After half an hour of poking around it was 5pm and he asked me to come back next week to investigate. Frustrating but to be fair he didn't try and charge me anything.
Got it home and up on my wooden ramps. I noticed that the spring on the offending corner wasn't quite seated properly so I rectified it. Thing is I can't see that making all that much difference to the geo. If anything would've just put the ride height back to something like SE and if anything reduce the camber. Maybe.
Strugglin to think what to do now. Thought I'd ask the wealth of knowledge on here incase anyone has encountered similar. Think I'll contact Lee at FCM in Bristol to book an appointment as I'm in South Gloucestershire.
