Hello Chaps,
I am looking to get my alignment checked / revised in the near future to try to get the car slightly more neutral and less inclined to under-steer. The car is used as a daily driver / fast road car (no track work) so I don't want anything too extreme that will shred the inside edge of the tyres in no time. I am running Goodyear Eagle F1 Asymmetric 2's all-round.
I have done a small comparison of a few cars setups:
This shows that the Z4MC set up is pretty conservative compared to the CSL and in some ways even the Z4MR. Also shows the MC & MR have the biggest front to rear toe difference (0˚ 18').
What I was thinking of doing was the following:
Front
Total Toe 0˚ 04' - this is the lower end of the MC tolerance/matches the MR.
Camber -1˚ 30' - as far as you can go with the strut pins out??
Rear
Total Toe UNSURE - I am not sure how far to go with the toe at the rear. The CSL is running 0˚ 04' to match the front but may this cause the Z4MC to be unpredictable with its shorter wheelbase?
Camber -1˚ 50' - OEM
I am hoping this setup would remove the slight outside edge wear I am experiencing on the fronts and also increase the front end grip slightly. With the rear I am hoping that decreasing the toe in will help balance the car out further while also reducing the inside half tyre wear experienced with these cars.
What setup do you lot use and what differences have you found by tinkering with the alignment?
Any thoughts welcome
Front
Rear
