R ross101 Member Jun 8, 2016 #1 Car seems to slightly pull to the left. Any ideas? Here was my last alignment readout that had no adjustment:
S Scooba_Steve Elite NW London & Somerset Jun 9, 2016 #2 Road camber? Have you found somewhere perfectly flat to try it?
R ross101 Member Jun 9, 2016 #5 Yeah I jacked it and span the fronts and they were fine spinning freely. Not checked the rears though.
Z z4pilot Senior member Lytham, Lancs Jun 9, 2016 #6 Have you tried recalibrating the steering angle sensor? Others have had similar issues and found that the angle sensor is off and resetting may help?
Z z4pilot Senior member Lytham, Lancs Jun 10, 2016 #8 Have a read of this; http://www.z4-forum.com/forum/viewtopic.php?f=3&t=84637&hilit=steering+angle+sensor+reset It's relating to wandering and inconsistent steering rather than a consistent pull, but it's worth having a look.
J JonathanFenton Member Jun 20, 2016 #9 Check your wishbone bushes. Replaced both rear bushes on the front wishbones and this resolved the steering issue i had.
