Yup. Same here. Got a spare from Barry (umfaan) and think he has morepilch said:The clutch won't engage. I've tested it.
You have to unbolt the compressor before you can do anything.Pondrew said:Is the clutch not a separate part? Always used to be, in the 'good old days'. The clutch is an electro-magnet. Seems a bit extreme to junk a whole compressor because of a faulty magnet. :?
Ah OK. In the days when I used to do this stuff (often), you could take the auxilliary belt off and release one bolt on the front of the clutch and remove it with the electrics still attached. Unplug the connector and then swap for a good one.enuff_zed said:You have to unbolt the compressor before you can do anything.
bigwinn said:Just make sure the system is empty of gas before swapping out.
See, instead of being so supercilious about it, why did you not try to be helpful and offer the benefit of your previous experience? It could be that your knowledge applies equally to these compressors and you could have advised us to try this first.Pondrew said:Ah OK. In the days when I used to do this stuff (often), you could take the auxilliary belt off and release one bolt on the front of the clutch and remove it with the electrics still attached. Unplug the connector and then swap for a good one.enuff_zed said:You have to unbolt the compressor before you can do anything.
Progress, eh?? :roll:
Indeed! It now carries a prison sentence for 'knowingly releasing CFCs or HCFCs into the atmosphere'.bigwinn said:Just make sure the system is empty of gas before swapping out.
Pondrew said:Indeed! It now carries a prison sentence for 'knowingly releasing CFCs or HCFCs into the atmosphere'.bigwinn said:Just make sure the system is empty of gas before swapping out.
Oh hang on I retract that knowledge for fear of being supercillious!![]()
enuff_zed said:As a follow up to this: I just took a look at the spare compressor and yes there was a torx bolt in the middle.
Try to undo it and the whole inner section of the pulley/clutch pack just spins.
Only way I could get it undone was to hold the outer edge of the front section in a vice. So that would be a challenge in situ.
Once the bolt was out I tried to pull the clutch assembly free. No dice. Nothing moving at all, and as I am intending to fit this I didn't want to mess it up.
So no real conclusion I'm afraid.
Yes it looks as though it should be possible. But still fitted? Not too sure. Will it actually come apart? Certainly not without a fair degree of 'gorilla-ing'.
So my plan now is to swap the whole thing over then experiment more on the old one which I know is knackered before I start.
Sorry [ref]pilch[/ref], I was hoping to be able to give more help than that. If you do yours before I do mine then maybe you could have a play with your old one?
