My 2.5 Zed had been baking in the sun all day whilst at work. On the way home (really hot car) the Tyre pressure light came on, well i felt no change to the handling of the car and assumed....its the heat affecting the system. Anyway i was only five minutes from home so i reset the tyre pressure sensor and drove home.
I had a quick look at the tyres and there was nothing obviously wrong.
So today i went in to the garage and reversed the car out and i could see the bottom of one of the rear tyres (Bridgstone RFT) and it appeared slightly deflated. Anyway, expecting the worst i rang a garage to see if they would repair it if it was a punctured in the tread area (they said yes) so i removed the wheel and took it to the garage where they checked it out. Low an behold it wasn't a puncture but it appears that the air had been lost between the tyre and the alloy rim, 15 quid to fix it (tyre off, sealant around the rim and new valve). The garage said they get around 30 cases of this a week and its quite common with alloy wheels.
So if you get a warning light indication like this, don't think the worst (as i did) there may be nothing wrong with the tyre! (Oh and please don't criticise me' for wanting to repair a RFT. I'm not made of money, i don't race the car round the streets and it was a nearly new RFT)
Hope this symptom helps somebody some day.
