Advice on which Z4 model to get
ManchesterMark
New member
Hi All,
I’m in the UK and have been looking for a new (second hand) car that looks good and is a bit of fun and I’m thinking that a Z4 would be ideal. I’ve got about 12k to spend. In terms of model, colour and options I would very much appreciate any advice from current owners from their experience as to what to look for/avoid. Thanks, Mark.
Hello.
Do you want a convertible, or coupe?
Do you want a first generation E85/6 (2003-2009) soft top convertible or tintop coupe; or a second generation E89 (2009-2016), hard top convertible?
For £12k you should get an exceptional E85 or 86, or a good fairly early E89 (2 litre 4 pot or 2.5/3 litre 6 pot.
There is a lot of choice of models, so depends what you require really! :thumbsup:
I was looking at the E89 hard top convertible. There’s a mix of 1.8s and 2.0 in my price range I can see. I was erring on the 2.0 but is the 1.8 still quite punchy - there seems to be a few of those about - or go for an older six cylinder? Is the manual a better drive or is the auto responsive (I’m used to DSG on VWs which seems quick changing).
I have an 18i E89. They are exactly the same engine as the 20i and 28i just strangled by the factory engine map. Standard an 18i, and to a lesser extent the 20i, are underpowered. However, for a very modest fee (around £300) they can be very safely remapped to give a very good car.
Without the remap, I don't think I would have kept ours, but it is a totally different animal now. We are talking 270bhp and 430nm torque and it's very safe, as the N20 engine was designed for a nominal 245bhp and 400nm (as in the 28i).
The only difference as factory standard with an 18i over the others, is you get manual a/c not 'very basic climate control'.
Admittedly I am biased, but for me the smart money buys a well-specced 18i (everything was an extra so specs are all different) as they are cheaper for a comparable car and get it mapped. Win win!
The 4 pot E89s use the ZF 8 speed torque converter gearbox. Mine is a manual E89 but had a 4 series with the ZF8. Both are good depending on your preference IMO. I think the older 6 pot cars had the ZF6 gearbox, which I also had in an Alpina. Nowhere near as good as the 8 speed. Others with autos will give better advice, on the Z4 gearboxes!
Thanks Pondrew, that’s just the sort of advice I was after. Thanks for taking the time to give me your perspective. I’m really looking forward to handing my lease car back at the end of the month and getting a Z4. I’ll also look into the remapping of the N20. Mark.
The 35i(option)and 35is have DSG boxes, a different kettle of fish though and probably over your budget.
I’ve not driven the automatic but from what I’ve heard they are very good.
I'd take a 3.0i E85/6 over an E89 4-banger any day of the week, but then I'm a bit biased.
The E89 is for women and old men who prefer comfort over sportiness. The E85/6 will reward you with a better driving experience and is much more becoming of a true roadster/sport coupe.
And don't even get me started on the G29. (just a slightly less lardy 4 series cabrio with a few more toys and questionable styling :fuelfire: )
For 12k you could even be looking at higher mileage Z4M E85's. A league apart and a massive step up over the 3.0i E85.
Welcome ….
You will get n factorial views on this where n is a large positive integer..
I had a 20i MSport Auto…a re-map transformed it (make sure you use a quality supplier and ideally use someone who does a before n after dyno)
That’s everyone’s view.
If it’s still on runflats tyres factor throwing them away…a majority viewpoint..
The auto box is fab…a majority viewpoint
Most people suggest getting one with heated seats..extended Bluetooth, idrive, middle range audio, parking sensors.. in some order..
Post 2014 20 litre cars avoid a potential cam chain issue..
Correct in my case. I am an old man and the E89 belongs to the wife.
You should ask for one for your birthday. You seem to fall into both categories, at differing times. :poke: :lol:
What I get up to on the weekend with a feather boa and a set of false teeth is purely my own affair Pondlife!
:x
Do it the female way… Buy an E89. Colour rules. And shiny things. Lots of them. Opening the bonnet just makes you messy. Happy driving. oh and apparently you have to have something called ‘E5’ put in it occasionally 🤷🏻 JL
(for removal of doubt, this is called irony, not to be confused with ironing, which I find men are actually good at) ♥️
The views are not THAT polarized - apart from the straight six v 4 cyl. I’m still drawn to an E89. I did just read about the cam situation - and I had that done on a 16v Golf I had a while ago which wasn’t inexpensive so ideally I’m looking 2015 for that (and more money up front) to be not an issue on the N20 or find one that’s had the cam replaced. Sounds like auto is a good option though.
The camchain and oil pump drive can be swapped out for about £1k so if you factor that in you may improve your selection options
:thumbsup:
It's worth mentioning that the camchain 'issues' on the early N20 are to do with wear on the plastic guides. Higher miles = more wear.
75k miles seems to be a minimum of when they start to wear out, so lower mileage shouldn't put you off an earlier one IMHO.
It's also worth mentioning that in over 2 years on this forum, I haven't heard of any failures of the guides. Not one.
If you only look at newer cars, either your budget will rise, or the mileage, or the quality of car will fall.
The N20 isn't like the N54 twin turbo engine which are a case of 'when something expensive is going to break, not if'.
Just to expand I know of 4 E89 N20s with noisy cam chains where the owners off loaded them in a hurry..plus 3 that failed terminally… :tumbleweed:
Pondrew has a Fens centric view of the world :poke: :rofl:
I like to think I have a logical view without any bullsh1t attached.
everyone is entitled to their opinion, though.
PS. I am not from the Fens. I am a soft, shandy-swilling southerner. I just live here, for my sins! :thumbsup:
Firstly good choice! We all have personal preferences, I am more of an E85/E86 fan. If it were an E89 I prefer the six cylinder variants and would go for the 3.0l but this is all personal preference!
To also weigh in on this, my experience is that the e89 is by far the better 'car', esp if long motorway trips are part of life, and if I were to only be able to have one vehicle, a 6-pot well-specked e89 would be my go-to. However, by good fortune that isn't my position, and as a fun thing to have, for me, the e85 wins hands down.
It depends what you want and your budget, if you want a cheap weekend convertible fun car an E85 is hard to beat
There are good 2.5 or 3.0 6 cyl that are a no brainer at £3000 or so, later facelift models have nice improvements. Automatic are good too at similar cost make driving in traffic easier, engines need to be properly maintained, later models have pros and cons at £10k plus, all are good car, decide on you price point and try a few.
