Hey Everyone,
I am trying to learn more about my car and starting to attempt some of the more trivial maintenance work myself! started with a service I carried out a few months back. The service went well other than a slight mistake on part number on the oil filter which I am still unsure what went wrong
. I used Real OEM for the part number but it appears under the same part number on auto doc there were two different types of filters and the one I ordered was sightly too tall... :thumbsdown:
Sorted in the end with another and now moving onto the brakes I was hoping for a quick check on my plans from the forum if possible
I plan to replace discs and pads on the front brakes of my 2003 Z4 3.0i and plan to purchase the following;
Parts;
Discs - Brembo Max Line Brake Discs - £51- https://tinyurl.com/xfwpkr5r
Pads - TEXTAR epad Brake Pad Set - £58 https://tinyurl.com/4rzp5k3c
Additional Tools and Lubricants;
Brake Piston Wind back tool - £30 - https://tinyurl.com/sye8su43
Brake Cleaner - £3.50 - https://tinyurl.com/eudzm2vk
Brake Grease - £3.75 - https://tinyurl.com/4va2fb26
Questions
- Do I need to replace the sensor?
- Do I need anti-seize to put on the new disc when installing?
- Is there anything I have missed?
- Any better suggestions on discs and pads? Car is used on normal roads with the occasional fast drive in country roads
. I used Real OEM for the part number but it appears under the same part number on auto doc there were two different types of filters and the one I ordered was sightly too tall... :thumbsdown: Sorted in the end with another and now moving onto the brakes I was hoping for a quick check on my plans from the forum if possible
Parts;
Questions
