Hello, having spent the past few days reading about bushes/poly bushes, I am a bit confused and looking for some advice from the knowledgable folk here! The last MOT on my car (2004 3.0i Roadster on 142k) highlighted advisories on the front bushes:
Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement rear bush (2.4.G.2)
Offside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement rear bush (2.4.G.2)
Nearside Front Anti-roll bar rubber bush deteriorated but not resulting in excessive movement d bush (2.4.G.2)
Offside Front Anti-roll bar rubber bush deteriorated but not resulting in excessive movement d bush (2.4.G.2)
I have a few queries:
1. I am considering going for poly bushes, but do these make the ride much harsher? I am on 18" wheels if that makes much of a difference.
2. Is it worth changing the rear bushes too or leave them for now? I have read some topics where people advise poly on the front and regular on the rear?
3. I'm not too sure on exactly the parts/sizes I need - is there an easy guide which explains this anywhere? From what I can gather, for the front I will need for each side an anti roll bar bush (24 or 25mm?), front wishbone rear bush (60 or 66mm?) and possibly an aluminium outer housing? Is this correct?
4. I have seen Powerflex come up on most recommendation threads, are these the best or any others to consider? Meyle HD?
5. Is there anything else I should consider getting swapped out at the same time? Drop links?
Any advice much appreciated! Many thanks
