Right, I'm pretty sure I have exhausted every search option on this topic and not found the answer so bare with me...
I've finally acquired a 2007 roadster (just 7 years after my initial test drive) after the starting a family put my idea on ice!
I have the base stereo 6 speaker set up. After putting in an aftermarket stereo and subsequently removing due to ruining the look of the dash I want to improve my sound.
So I've ordered some 2 way 6x9's to go in the rear cubby hole's which I plan to run from the rear speaker wiring and not use the factory speakers.
I have also ordered 4" speakers for the doors to replace the current blanks which I will run off the tweeter wires.
Now to run this I've ordered a Pioneer GM D1004 compact amplifier that looks like it can run directly from the stereo with a din adapter. It's here...
https://www.pioneerelectronics.com/PUSA/Car/Amplifiers/GM+Digital+Series/GM-D1004
Now will this work?
Or have I ordered all the wrong stuff?
I know dangerously little about car audio and amp's so ideally want to avoid setting fire to my beloved zed!
Any advice would be much appreciated! Thanks
Now will this work?
