Bikerbilly
New member
Need advice from the Z4 collective mind. Just bought a 2004 (E85) auto, 2.5. Looks like the previous owner did a heater core delete (by blocking off the two hoses going in & out). I thought they did that because of a leaking heater core. There was no heat coming out of the vents (even though it was set on max heat). I unblocked and replaced the two hoses. Now there's heat and confirmed that there's no leak or funny smell coming from the heater core and no coolant leak. But now I realized that there's no cold air when I turn on the AC. I confirmed that there's plenty of freon and the compressor works. The flaps that divert the air vents work. Swapped out the climate control module and still has same issue. What else can I look into?
