Ah okay... found out what it is.
Works in conjunction with the wheel speed sensors, yaw (rotational rate) sensors, steering angle sensors, and lateral acceleration sensors to determine if to active ABS, DSC/DTC, and to calculate the force for EBD.
DSC pressure sensor
The DSC pressure sensor(s) provides the ABS/DSC control module an analog
voltage signal in proportion to brake pressure in the master cylinder.
The DSC MK 20 and MK 60 systems use two switches installed at the brake
master cylinder.
The Bosch DSC III 5.7 system uses one switch installed at the DSC hydraulic unit.
