Just a quick bit of feedback for you all from the repair side of this business!
I am having an influx of BMW's with driveshafts where the toothed wheels (Reluctor or phonic or....) have bulged outwards due to corrosion getting underneath. This results in the ABS sensor being gradually eaten away to a point where it fails. As this develops, i am getting "wheel speed sensor interpolation" on my scan tool.
For the uninitiated, interpolation is the science of guessing what data was if it is missing. As I tried to explain to one of my sons for his degree work......If you take the temperature everyday for 7 days, but lose the data for Wednesday, it is possible to guess (or more accurately "intelligently determine") the missing one from the others. Yes, there are formulas for interpolation, but not going to bore anybody!! Having a maths degree certainly helps me with modern day cars!! But my Wife says its boring!!! Blah, blah, blah....she says.
As the sensor hits the distorted toothed wheel, the signal changes instantaneously (reduced air gap) and produces an implausible signal (or one that is different to the rest). The computer disregards this and substitutes a value to complete the calculation.
So, what am I saying? If you get the interpolation word, it is highly likely the driveshaft and sensor needs changing.
On the other hand, when a single speed sensor fails, the 3 lights will light up on the dash, and also the tyre pressure warning light. Obviously because the frequency of the signal from the speed sensor varies as the diameter changes. So the computer knows the tyre is going down by sampling the waveforms from each wheel and looking for an increased frequency (shorter "period" for the scientists out there!
All this is not concrete but will give a guide as to what may be wrong.
Just some secrets from the trade :wink: .
Andy.
Andy.
