Bored as hell today during lockdown so decided to use the upgrade kit from i6 which I purchased about a year ago purely as a preventative job. Car is the 2005 2.5SE and has covered just under 60k miles .
Not much play anywhere with just a miniscule movement at the pin. No problem with swapping components over but noticed with everything back in place that when you twist the flap it pushes a plastic (actuating)arm into what I assume is a diaphragm. It all feels nice and smooth until about 90% of the available travel that there is a kind of clicking sound and the arm jumps a bit when it reaches its maximum movement. The arm similarly clicks and jumps slightly when releasing the pressure on the flap.
As I didnt have any problems with the DISA before fitting the i6 upgrade can I assume that this is normal or is it pointing to an upcoming issue with the unit as a whole.
