Hi everyone,
This concerns my son’s 2003 E85 2.5i. I know there’s been lots of posts on steering angle sensor issues, but I can’t find one that matches. Any help or advice greatly appreciated.
We had the usual trifecta of warning lights - amber handbrake, TPS and ASC.
We’ve cleaned and re-installed all the wheel speed sensors.
I’ve got hold of a Creator 310+ and got the following results:
In the ABS menu - Fault code 5E40 steering angle implausible. In the DSC sub-menu, live-feed, the steering angle measures OK lock to lock, so I guess the steering angle sensor itself is working.
In the EPS menu - no fault code. In the live-feed, the steering angle speed appears OK in both directions. Again, this suggests the steering angle sensor is working OK.
In the LEW (SAS) menu - no fault code. In the live-feed, the steering angle measures OK in both directions, but after 4 seconds changes to -325 degrees. Each time I exit the live-feed and re-enter, the same thing happens whether I’m turning the steering wheel or not; it reads the correct values for 4 seconds, then snaps to -325 degrees.
All other live-feeds seem to be OK, and the only error code is 5E40.
The above makes me think the SAS is OK and it must be something else. Anyone come across this or got any ideas?
