4 Wheel Alignment
TheDan
 Warwick, UK
Hi all,
I have just been quoted by Rybrook in Warwick £189 for a 4 wheel alignment... :exitright:
I know its important to find a reputable place to get the alignment done (especially as I am after somewhere that will apply the Z4M settings over the standard Z4 settings).
Does anyone know a good place near Warwick/Leamington or more widely in Warwickshire that will do this for a reasonable price?
TheDan said:
Hi all,
What's the advantage of having a Z4M alignment over the stock standard Z4 settings?
Here is a quote from this thread (https://z4-forum.com/forum/viewtopic.php?f=49&t=107556) explaining why (the main difference is the rear camber):
Wheel alignment
I’ve been contemplating whether to add this or remove (as technically its neither wheel nor tyre related) and think that I’ve settled with leaving it as read. While not 100% related but it does have its links, and when I set out making this I wanted lots of info in once central place. It is a lot of info so feel free to skip down over the techy bits.
Incorrect wheel alignment will have an adverse effect on handling and also tyre wear. If you’ve not got any paperwork to support a recent alignment it may be wise to get an alignment health check.
Be weary of getting an alignment at the likes of QuickFit, etc. They’ll not be able to offer you a bespoke service and may say some elements cannot be adjusted without going to BMW. Like for example the front camber. The reality is that if the place know what they’re doing, they’ll be able to properly adjust your car. If they don’t, well do you really want them adjusting your car?
To cut a long story short, and if you’re new to the scene then a simple Z4 M alignment set up will hold you in good stead. If then you want to take things further and tweak things, then you can.
Most people want less understeer, which is inherently built into the factory setup. This is particularly apparent on non Z4 M models with so much more rear camber than front.
Front Camber
It’s reasonable to aim for maximum front camber (by pushing the pins all the way in). It will vary from car to car but this usually ends up with similar front camber in the region of 1.5 degrees plus or minus a quarter. You should then try balance the camber left and right back to whatever the lowest common denominator. For example if one goes to 1.5 and the other only goes to 1.3 get both at 1.3.
Front Toe
It's not generally advisable to run toe out on either end on the road as it's a bit too lively and not nice on the motorway with more potential for less straight line stability.
The front can be run at parallel or close to zero without any major adverse effects. It's why I often commented to aim for 0.02-0.05 on both sides.
Rear Camber
Rear camber should be in the region of 1.5 degrees plus or minus a quarter. You should then try balance the camber left and right back to whatever the lowest common denominator. For example if one goes to 1.5 and the other only goes to 1.3 get both at 1.3. You may find the stock adjustment doesn't go that low if the bushes are worn so just take the same approach as the front but aim for minimum rather than maximum camber.
If you’ve made adjustments to the front and rear camber and they end up with similar values at the front and back, keep in mind that it’s better having more camber at the front. So a setup like 1.4 front and 1.3 rear.
Rear Toe
Rear toe is the final factor then and the closer you run it to zero the more lively the rear end will be. Usual suggestion is to run a bit more than front but less than factory if you want a sharper car. With all other parameters set this is the one you could play with to add or remove oversteer to taste. I found it was not overtly lively running low numbers like 0.04-0.06. Again balance the left and right back to the lowest common denominator.
If you aren't aware the measurements are shown in minutes and seconds versus degrees. For example 2o 24 is 2.4 degrees. There's 60 seconds in each minute so 24/60 is 0.4 degrees. The numbers I mention above are in degrees so you're aiming for rear camber that reads something like 1o 15.
I got my z4 set up by Spires Technology on heathcote industrial estate. More used to setting up racecars and suspension, but very knowledgeable, should be able to set it up exactly how you want it.
https://www.spires-st.com/
Oh and ask about swapping out the rear lower control arms for ones off an e46 m3, for better control of rear toe angles - m3 ones are a ball joint, standard z4 ones are a rubber bushing.
The place localish to me with a hunter system charges £18 for each adjustment.
If only 2 wheels need adjusted its £36.
Hi, I can't recommend anyone, but I've done my in Manchester for 140£. I thought I was being ripped off, but they probably do an alignment, correction and another alignment to make sure it's good.
I paid just a bit over £130 for one from Bartletts Automotive, a BMW specialist in Peterborough. I also asked them to carry out an M alignment which didn't go to plan, they had a really hard time with it and I ended up taking it back at which point they just carried out a standard alignment. Might just be because my car is lowered but :?
Not Near you but Forest Tyres
https://www.forestofdeantyres.com/
carried out 4 wheel laser alignment including all adjustments for £50 for a normal 4 wheel check and adjust
Have had both X5 and Z4 checked and adjusted - while you wait , they explain the current set up from the computer , explain what needs to be done and then carry out Toe, camber, trail etc until within tolerance. You can watch it all being done and see the settings come up on the remote screen. Pre and post print outs provided for service history
I have also seen them setting up Rally cars to individual requiremets.
Its a little gem of a place
