Hey guys,
New Z4 owner here, and I seem to have a slight issue.
I've noticed on startup what can only be described as a whoosh noise. It only happens when cold and the car has been left overnight. I also get a slight rattle when the engine turns off. Any other time (free revving, revving in gear, idling) it purrs like a kitten, no rattle.
The second issue is during acceleration. Sometimes when revving above 3000rpm the engine seems to hesitate, and sort of stutter between 4000rpm. Up to 3000rpm it is perfect, and sometimes between 3000 and 4000 it is fine too. There is no noise associated with it, the car just feels a bit jerky for a few moments, then it's fine again. It seems to mostly happen on light to mid throttle (at least that's when I've noticed it). Doesn't seem to matter if it is in "Sport" or not.
Accelerating from standstill and shifting before 3000rpm is smooth, and there are no issues when cruising at a constant speed (cruise control or not).
I've got a statutory 3 mth warranty from the dealer I purchased it from, so if it's something serious I want to get it rectified by them immediately. I've done some searching online but it's been hard to find an answer.
My Z4 and I thank you
