35is service schedule
Hi
Can someone reference the service schedule for a 2013 35is that has done 13,000 miles to date.
i.e. what services should have been done by now, and what should be indicated in the service booklet. I just want to check mine has been all covered.
I cannot find anything specific on the internet.
It's conditioning based service and will require a service every 2 years or Depending on mileage it could be required before 2 years. When you switch the ignition on you are presented with numbers and theses are the miles until the service. If you have idrive then you can also check on there.
Oil services are based on mileage or years whatever comes first and brake fluid is every 2 years.
Given the mileage it shouldn't have needed or had a service yet and unless you plan to put lots of miles on it within the year then you'll probably just need it done at 2 years but the dash will tell you and your handbook tells you how to check this.
Angie is absolutely spot on I believe! :D
My previous E89 (28i) had brake fluid change at 3 years but maybe the 35i Is different.
Oh yes that's right from 2012 brake fluid became 3 years for fhe first one and every 2 years there after. Well reminded dr_john
Thanks for the detailed reply. Appreciate it.
I was a bit concerned that there are no service stamps in the book. But it's as it should be.
Love my Z4 !
I think my Z4 has it's first service at 2 years and I think 23k miles ... times have changed from years ago - I remember my Phase 1 Renault 5 GT turbo needed an oil change every 3K miles !!
