Hi all,
Bit of background; I have an '06 Z4 Coupe 3.0si Sport, which after ~4months of ownership I am very fond of... however...
I have a few bug-bears as regards the driving experience...
1. The horrid tailing off of the power past 6,500ish rpm. It’s a sports car, it should pull hard to the redline, which brings me on to the next point;
2. Soggy, artificial rev limiter. Rather than a decent one, it’s electronically mapped in to completely tail the torque off so the redline is reached at a significantly more sedate, and less offensive pace/volume! Again, it’s a sports car, I want a bit more drama, not this limp wristed tailing off. In my opinion it would also significantly improve the pick-up when changing to the next gear, as I find it tends to drop the revs ever so slightly too low if you change at 6,500rpm…
3. Raise rev limit to 7,300rpm.
4. Remove/map out the torque limit in 1st – yes I know it’s there because you don’t need all the power in first, but it’s annoying; I want to decide how much power goes rearward on the throttle, thank you!
5. Over-assisted steering in 'Sport mode'. It’s not that much of a problem in non-sport mode, but it does I find tend to make it a bit vague in general, something I want to dial out a lot more when putting it in sport mode for fun driving. I could be wrong, and this could be to do with needing suspension refreshing, but I’d rather like to reduce the assistance in sport mode in the hope of gaining a bit more feedback, and a bit more resistance immediately off-centre…
Has anyone else on here experimented with mapping the above parameters, and if so what was the end result like to drive? Were they worth doing? I’ve been in touch with a reputable mapper in the Bournemouth, and have discussed my thoughts and what I’d like to achieve, and he has said it’s all achievable, and he will save the OEM parameters to revert to if I’m unhappy with the results.
I would like to highlight that I'm not going for, or expecting a super duper heap more power or torque; just trimming/smoothing of the existing torque curve, and modification of the above parameters...
Thoughts?
Thanks in advance
Ed
Thoughts?
Thanks in advance
Ed
