Hey Guys,
What I suspect to be the electronic water pump on my Coupé has recently started making a lot of noise and I would like to put the pump into it's 'self bleed' procedure.
I have tried many times using the steps outlined on this thread over on Z-Post.
The issue I'm having is that I simply can't get the pump to bleed at all! No matter what I do, or how many times or how carefully I follow the guide, It does not play ball.
Now, I know my Waterpump is working perfectly as the car gets up to temperature in a good quick amount of time and does not rise above the mid-point on the gauge or over heat.
However the issue I'm having is a whining noise - Which is only there when hot - It's silent on idle, but whines increasing in pitch as I gently raise the revs. By 1400rpm the pitch of the whine is at it's highest and remains the same pitch for the rest of the rev range.
It does not do it when cold!
All I want to do is get my electronic pump running without the engine running, So that I can tell for certain that it is indeed the pump making all this noise!
I'm almost certain that it is - Lets face it, What else would only run when the car is up to full operating temperature and what else would raise pitch when bringing the revs above idle speed.
Any Help - Hints - Tips - Tricks or videos would be very gratefully received as this is really frustrating me now.
Sat here with money pouring out of my pockets reluctant to purchase a new pump until I know for sure it's that... lol
