3.0Si gearbox - plugs and washers
ChrisN53
Hi guys,
Ordered some new gearbox oil for my 2006 3.0Si Coupe as I can almost guarantee it has never been changed. I went for 2 litres of Redline MTL 75W-80 GL4.
I want to replace any washers and both the fill and drain bolts when I do the change. But I have stumped as to where to order them from (other than phoning up/going into main dealer). What's a good site to use?
Thanks all, appreciate it.
Chris.
Thanks. Tried RealOEM as well to just get a part number, but am struggling on both sites if I'm honest :(
EDIT. Right, think I've found it. Both fill and drain are the same "Screw plug with gasket ring, M18X1,5", part number 23 11 7531356. But it doesn't look like they stock it.
Worst case; what is the risk with reusing my existing fill/drain bolts?
Dealer is probably the best place, they're only about £5 each. Try Soper Lincoln and mention the forum for a 10% discount (although often they are half the price of my local).
I noticed a lot of difference when I did my change. It was well overdue looking at the state of the oil! Do your diff too while you're at it.
I think it's this p/n: 23117531356 but confirm with the dealer. Hex plug with a green washer built in from what I remember.
Will Soper Lincoln deliver then? I think you're spot on with the part number too - I've edited by previous post.
Yes, Soper deliver and are pretty quick. Make sure your local doesn't do them cheaper though, but it's unlikely.
