3.0Si BIG BRAKE UPGRADE (complete)
Zedebee
Veteran
 North Hampshire
Everything you need to upgrade a sub-3.0Si to full 3.0Si front brake spec.
Included:
  • Pair 325x25mm front brake discs OEM Bosch
    Pair 57/25 front brake calipers OEM ATE
    Pair matching caliper carriers OEM ATE (hard to find now)
    Set of EBC blue stuff pads
    Springs, bleed valves, slide pins
This is a bolt on upgrade for 2.0i/2.2i/2.5i (286x22mm) or 2.5Si/3.0i (300mmx22mm). Suitable for both pre- and post-LCI cars. A real performance upgrade while keeping all the hardware OEM.
Everything is in good condition and has been cleaned up. They won’t need much prep for painting, or can be bolted straight on. The calipers and carriers are barely rusted, while the discs and pads have plenty of life in them. One of the discs has a score in the outer braking surface from a trapped stone, but this will disappear over time.
£200 collected, or plus UK postage.
IMG_4105.jpegIMG_4106.jpegIMG_4107.jpegIMG_4108.jpegIMG_4109.jpegIMG_4110.jpegIMG_4111.jpeg
[ref]Zedebee[/ref], yes happy with these and looking forward to collecting and meeting you. Thanks
